I'm in the process of converting my 66 L-72 to power steering. I have many of the parts needed but some parts are from a 1964 Chevrolet passenger car, Thus I have a few questions. I also have a 1964 SB 327/300 Corvette with (as far as I know) factory power steering, so the 64 will serve as a reference.
1. From what I can tell, I should change the center link to the .75" 3822693 or the .90" 3952707 & the pitman arm to the PS 3741383. But, when I looked at the part # on my 64 SB pitman arm the number is 3831473. This is a number that I have not been able to find in my parts book. Does any one know of this number?
2. I have several early style PS pumps one has SB brackets & the other has BB brackets. The cast iron double deep groove PS pulley (3878245) on the BB pump has some damage & should be replaced. The Corvette parts catalogs that I have looked at indicate that the PS pump cast iron pulley they supply is for use on pumps with a tapered shaft & lock nut. Both of my pumps use a small woodruf key & a lock nut, but neither pump has a tapered shaft. Is there an available BB pulley to fit the non tapered shaft pump?
3. From what I've read the hydraulic cylinder, control valve, & pump, should be the same for a Vette as for a pre 1965 passenger car. Is this correct?
Thanks in advance for any comments.
