How much does it take to due your system, am changing to Silicone with new Master Cylinder, can I unscrew all lines then let drain out then use Denatured alcohol to clean all lines then blow out then install new cylinder, pour into open lines till flowing out all lines well, tighten then proceed to bleed, or what is the best procedure for this, am installing original front drum
brakes on from discs. Thanks, Brad.
