I have tried to read other postings to not be redundant but could not find an example where the gauge does not move. So for the electrical Buffs out there, here's the puzzle:
The battery gauge had full operation, negative and postive. I realized the capacitor attached to the mini cluster was not hooked up to the gauge, and (while forgetting to unhook the battery) I got under there to hook it up. In the process of doing so, I sparked the capacitor to the back of the gauge
and there you have it. I am admitting my failure to my peers to begin the healing process.
I thought I fried the gauge right there, even though it was a it was a very small and quick spark - not a smoldering electrical charge. But to be on the safe side I pulled it and had it tested by Corvette Instruments in FL and Roger said it is A - OK. No damage to the gauge. Also noted, I did blow the 10 AMP fuse.
So upon reinstall of gauge, fuse and capacitor, the battery gauge needle does not move! I re-snugged the fuse box to firewall, checked voltage regulator clip-in and it is snug, battery cables are tight.... even put a load on it - left lights on, etc, just to see if I can get anything at all - and nothing. No movement negative or positive.
Any advise is greatly appreciated. I will test suggestions with the battery disconnected/connected as appropriate.
Thanks, Dan
Thanks, Dan
