I'm looking to determine if the fuel gage, the sender, the harness or a combination of these are faulty. The fuel gage is stuck at about 3/4 full regardless if the engine is running or not (ignition on or off with the tank less than 1/4 full of fuel).
Can the fuel gage be tested (using a volt-ohm meter for example) from the wire harness connections at the tank sending unit? I'm trying to determine if the fuel gage is bad without removing the gage or dash cluster. I'm wondering if any fuel gage checks can be made at the wires connected to the tank sending unit if the wires are disconnected from the sending unit.
Also what voltage should be measured at the sending unit wires?(with the sending unit disconnected)
Can a fixed resistance (like a 45 ohm resistor) be placed across the disconnected sender wires at the tank end to simulate a 50% gage level reading for example? (Trying to determine if the sender is bad)
Appreciate any troubleshooting hints. I have a volt-ohm meter and access to fixed resistors for testing. Thanks much.
