Finish for brake switch assembly bracket - NCRS Discussion Boards
  • Steve L.
    • June 30, 2001
    • 763
    This is the brass block with the pressure warning switch GM 3980797. There is a steel bracket swedged on. I'm looking for the finish on the steel bracket.
    On the bottom surface of this bracket that faces the frame, there looks like there is a small area that shows yellow chromate for a finish.
    Is this correct.
    This is for a 73
    Steve L
    73 coupe since new
    Capital Corvette Club
    Ottawa, Canada
    • 43193
    Re: Finish for brake switch assembly bracket
    Is this correct.
    This is for a 73
    Steve-----
    Yes, the attached steel bracket was zinc plated with an irridite ("gold") overplate.
    • Steve L.
      • June 30, 2001
      • 763
      Thanks again Joe
      Steve L
      73 coupe since new
      Ottawa, Canada
