67 3x2 center carb accelerator cam help - NCRS Discussion Boards
  • Dereck S.
    • July 30, 2008
    • 244
    Looking for some help on the correct 1967 3x2 #3660 center carb accelerator pump cam. I have an orginal early center carb dated 691 that I'm rebuilding and noticed it has a worn plastic accelerator cam. The cam on the carb is semi-transparant plastic with the number 240. I need to know if this 240 cam is original and correct. If so, where can I purchase a replacement? Holley has 240 cams on their website but they are red in color.
    thanks,
    Dereck
  • Clem Z.
    • January 1, 2006
    • 9427
    Re: 67 3x2 center carb accelerator cam help
    thanks,
    Dereck
    240 is the correct cam
    • Clem Z.
      • January 1, 2006
      • 9427
      here are the numbers and colors. https://www.forums.ncrs.org/attachme...00776&uid=9770
      • Dereck S.
        • July 30, 2008
        • 244
        Thanks for the info Clem. Sounds like the color of the plastic was changed at some point.
        Dereck
