68 Nos Outside Door Weatherstrip - NCRS Discussion Boards
  • Jeff P.
    • 797
    Not the felt wispies but the rubber outside strip up against the glass. I know there are some NOS ones out there,just thought someone could use the cash. The reproductions aren't exact I heard. Need both sides and am offering a finders fee for your help. Thank You, Jeff
    68 L79 Convertible: Triple Black: Work In Progress, Body off. Now on!
    2014 Arctic White Z51 Vert. (Wifes)
  • Dan M.
    • March 6, 2009
    • 157
    Re: 68 Nos Outside Door Weatherstrip
    I don't have the items you are looking for but you may want to specify whether its coupe or convertible door items you are looking for. I think there was slight differences between the two.
      Jeff------
      There were three different designs for the 1968 outer window seals. Only the second ones survived in SERVICE for many years and they have been discontinued for a long while now.
      • Jeff P.
        • 797
        Thank you Dan, this is for a coupe both doors.
        Joe,
        This is a March build so I would imagine it is a first or second desighn. Interesting, never knew that. Can you tell which desighn from the looks ? Screws, staples, ect ? Guess I'll have to look real hard at Bloomington and Carlisle. Thank You, Jeff
        • Ronald L.
          • October 18, 2009
          • 3248
          I think I saw some last month Gm, if you can post the part numbers I can check back with what I saw asn the discussion was how bad the repros were.
          • Jeff P.
            • 797
            Thanks, Ron,
            Good time to have a 68 parts book.I have to invest in one. Jeff
            • Ronald L.
              • October 18, 2009
              • 3248
              Jeff the AIM Assembly Instruction Manual for your car 1968 is invaluable, about a $20 investment, that will given you the MY correct PN's and then let me know what those numbers were because I looked at a C3 pillar strip, GM, CRC, MRP, and others economical imitations.
