"A" Arm Cross Shafts - NCRS Discussion Boards
  • David L.
    Infrequent User
    • March 23, 2010
    • 6
    I recently purchased a 66 Convertible (194676S111360) from the original owner. The car has a build date of January 18, 1966. The upper A Arm Cross Shafts have one of each style, Round on the right and Square on the left. Everything on the car is original and has the correct date codes and numbers. The judging guide says that this situation occurs until approximately late December 1965. Do you think I will have a problem with judging? What if anything should I do to document this?
    Thanks for your help.
  • William C.
    • May 31, 1975
    • 6037
    Re: "A" Arm Cross Shafts
    Approximately should keep you in order for judging. That means no definative cutoff was established.
    Bill Clupper #618
    • Gene M.
      • April 1, 1985
      • 4232
      If no evidence of collision repair, then just leave it as is. Two styles is common. I don't recall the time peroid but just the same they are out there and original.
