Good morning fellas,
I am hoping someone may be able to shed some light on the issues Im having with my 58 4900R unit. The unit is a monster eating FI drive cables, going through a half dozen so far in as many days. It does fine until I do a full power run, then usually right as I let off the cable pops. I actually suspect the distributor, since the out layer of the cable that fits into the distributor twists off every time (the end with the button on it).
I have been greasing the cables heavily with wheel bearing grease every time, and I have the repo short cable housing which matches up with the short cables (all purchased from Paragon).
I imagine there is only one company manufacturing these repos, but was curious if you all knew if there are different suppliers with varying quality levels. If not I guess I'll have to break down and replace the distributor cross shaft...
