Re: 1966 Trico wiper blades
Henry,
I agree that it was very common practice to just replace just the rubber inserts in the 60's, 70's, and even the 80's. I think it is very possible that your "flat roof" Trico wiper blade holders with "TRICO" and "MADE IN USA" are original equipment with a April 1966 dated car. I believe that sometime after April 1966 is when the switch was to the "roof peak" Trico blades. I am sure that Pete might know the approximate date of this changeover.
I just found a pair of 15" Trico (satin finish) "flat roof" wiper blades in one of the many boxes of wiper blades that I have collected over the years. I removed these blades on Jan. 31, 1992 from a 1967 Pontiac Tempest 6 cyl. in a salvage yard in Phillipston, Mass. The holders are stamped "TRICO" and "MADE IN USA" on the top end only. The rubber refills must be replacements as they do not have the 3 ribs. Unfortunately, I did not record the build date of the 1967 Tempest on the tags. I suppose that these blades could be replacements but I really doubt it as these blades (GM # 3887568) were discontinued "over the GM counter" in December 1966.
I also found another 15" Trico satin "flat roof" that came off a 1967 Chevrolet and is stamped "TRICO" on the top end only. I got this blade from a salvage yard in Templeton, Mass., in January 1991 but again, no body build date recorded on my tag. The rubber refill is a replacement refill since "ANCO" was molded into the rubber.
I now really think that the "TRICO"/"MADE IN USA" flat roof blade were installed on the 1966 production lines. I also believe that the "flat roof" Trico wiper blades were installed on "early" 1967 Chevrolets and Pontiac Tempests.
Dave
Henry,
Dave
