There is a guy selling an air filter that starts with "Best When Used" to me it looks like stamped the first three words.I dont know how to bring it over but it's on EBay Motors First page.When asked he played dum and said he found it at a yardsale.Any experts want to give thier opinion? I did put a bid in. Thanks,Jeff
A212CW air filter
Re: A212CW air filter
Larry $455. was the winning bid. The letters are totaly different in the first 3 words.I would like to be there when he takes the top off the air cleaner and shows it to a judge that is savy to an original.68 L79 Convertible: Triple Black: Work In Progress, Body off. Now on!
2014 Arctic White Z51 Vert. (Wifes)- Top
- Top
Dave, are you certain about the mesh? I'm under the impression the reverse is true. Square mesh = midyear. Diamond expanded metal = 68-72- Top
I think you'll find that the midyear A212CW elements used the square-pattern solder-dipped round wire mesh, oriented diagonally, and the "expanded-metal" (from flat stock) mesh appeared much later.- Top
My experience with AC filters of the 68-72 era is as follows:
The square mesh (horizontal/vertical) was used in the 68-72 era and possibly beyond. The AC 329C filters of the 70-72 era used the same mesh as the AC212CW's. Original filters I have seen use a thinner wire than some of the later reproductions. All from that era had BEST WAY..........silk screening.
I have not seen the solder dipper round mesh oriented diagonally as John describes. That was a later technique. There are other nuances that are hard to describe.
My information comes from original cars and filters from service that are dated in the 69-74 time frame.- Top
This is the square mesh a212cw.Attached FilesKeith Burmeister- Top
That's what I always thought. And I used the diamond pattern on my 70 and was never told it was incorrect in four judging meets, including a National.- Top
- Top
Thank you Mark. That picture makes me feel all warm and fuzzy.
That heater hose has been in the back of the Z06 since Gettysburg. It has been to PA, Iowa, Michigan and Wisconsin. It is just waiting for you.
The good Lord willing and the creek don't rise it will be at St. Charles. Be sure to bring your raincoat.Terry- Top
I can't dispute what you show but that is a service replacement from late 1969. Maybe my thoughts about a thin horizontal/vertical mesh are more related to 70-72 rather than 68-69. I've seen to many 212CW's and 329C's on original 70-72 cars and in service boxes to think that the filter you show is correct for that time frame. I'll respectfully disagree.- Top
