Following these instructions:
I've gone through the whole process exactly as described. The rotors were already drilled out so that was not a problem. I've applied "pressure" with a swinging 2 pound hammer and the bearing support will not come out at all. Should I use a larger instrument? Or is there another trick?
Any tips you can provide would be helpful. It looks like I will not have these out to bring to Bloomington and drop off for repair.
FYI I'm waiting to remove the rear spring bolts until later, to follow up on a previous thread.
Patrick
Patrick
