Re: Now I can't remove the rear bearing support...
Patrick
The best thing to do is take off the TA off your car.
If you have access to a 5 ton press it is the best way to go. I did this to my 2 trailing arms and it took a hour or so for both sides.
Hammering away with a spingle knocker and not enough room only accounts for bashed fingers and frustration of banging away for an hour.
Just like the BP trying to plug a hole. If they had built it right the first time there wouldn't be a problem.
If any of the nuts are rusted on then a heat with a torch and wahlah!!!
If you were near me I'd do it for you for a pizza. I took my trailing arms to work as we have mechanical shop for our food processing machines.
I never worked on this stuff before and it was straight and simple for a Produce salesman.
Thanks, grant
Patrick
Thanks, grant
