Tire - NCRS Discussion Boards
Tire
  • Mike M.
    • February 18, 2010
    • 10
    Tire
    Can anyone tell me what tires and brand are correct for an early 66 production? I heard they were either Goodyear or Firestone; Is there anyway to check which should go on mine? Also, who has the best price on the correct tires? Thanks
  • Jean C.
    • June 30, 2003
    • 688
    Re: Tire
    Mike, if you have the '66 TIM&JG, the OEM brand tires are listed therein. Should you not have the manual, I suggest you purchase one from the NCRS on-line store. You will find a vast amount of information in the manual. I am sure a '66 owner will reply to your question regarding what is correct for the car.
    Best regards,
      Re: Tire
      Mike------
      Goodyear and Firestone tires were definitely used for 1966. I believe that U.S. Royal, B.F. Goodrich, and General Tire were also used.
      There is no way to know what brand/model tires were originally installed on your car unless you happen to have the original spare.
      Reproductions of the Goodyear tires are available from Kelsey Tire. Reproductions of the Firestone and, possibly, B.F. Goodrich, are available from Coker Tire. Usually, the Coker offerings are a little less money than the Kelsey Goodyear reproductions, but the Goodyear reproductions are usually a little more accurate. I don't think that anyone besides Kelsey and Coker supply reproduction tires for Corvettes. You can purchase them through other vendors, but they originate from either Kelsey or Coker.
      • William L.
        • February 18, 2010
        • 22
        Re: Tire
        I have the original spare in my 66 which has never seen the ground, has the original stem, cap and weights and perhaps St Louis air inside. The tire is a U.S. Royal Laredo white wall and appears not to have any dry rot or other issues.
        Bill Lutter
        • Stuart F.
          • August 31, 1996
          • 4676
          Re: Tire
          I have the original U.S. Royal unused spare in my 63 as well, but it won't touch the ground except in a true emergency.
          Stu Fox
          • Mike M.
            Director Region V
            • August 31, 1994
            • 1464
            Re: Tire
            William, what color.
            All vendors did not supply all colors.
            HaND
