Re: New Owner Needs Numbers Match Help
Ok Shelton, you can use the VIN or your car to determine the approximate day your car came off the assembly line, there are calculators available to gain that information, all you need to do is supply the serial number for your car. Although a lot of emotion surrounds the issue, there is no practical difference between a block that the Flint engine plant built for a Corvette vs one for a passenger car other than the ID number applied to the pad on the front of the block, so since the engine had to be built and shipped (rail) from Michigan to St louis to be assembled in a Corvette (or passenger car on the other side of the wall at the St. Louis facility) your first step is to find a '63 327 block (or complete engine) with dating characteristics that predate the build of your car by a reasonable time period, generally a couple of weeks. Then you can decide from some of the remaining features on the car (tach redline for starters) what engine horsepower the car was originally equipped with. The 1963-64 NCRS Judging manual and technical guide have some insight into this process, and lots of members would be willing to help. One small flaw is that there are no clues as to a 250hp vs 300 hp configuration, so if the tach redline indicates a 250/300 engine, then unless you have aprotect-o-plate or other documention with the car, you will be on your own in that decision. Keep in mind that the first step is to study the car, and any paperwork that came with it to learn what it was, and then work towards returning it to that configuration. Once you have a pretty good idea of what it was originally, then you will know what you need to recreate that configuration, and it is up to you to decide how hard you want to work toward that goal. It can be a task that is as simple or as complex as you choose to make it, but the best thing to remember is the old carpenter's rule of measure twice, cut once! Do your homework first before you open your wallet and you will be far ahead when you declare your project "finished" (they are never DONE!)
