TI
Re: TI
Production engines run "lean" A/F ratio at cruise - stoichiometric on modern engines, and a little richer on vintage carbureted engines due to uneven fuel distribution, but the Rochester FI system can run leaner than stoich. because it offers very even fuel distribution.
The above is why production cars always have inductive ignitions. Lean mixtures require a long duration spark for consistent ignition with minimum misfires.
CD ignitions have intense short duration sparks, which are best for consistent igntion of rich mixtures with very high compression ratios. Even though the MSD system offers multiple sparks at low revs, the second or third are signiticantly retarded from optimum timing
The CD ignition is another example of a "race car part" that is not very well suited to road engines.
Duke- Top
Re: TI
We put a MSD unit and coil on our '72 fat motor almost 15 years ago and have nothing but praise for it. Fouled plugs are a thing of the past. The idle speed increased about 400 rpms when it was installed. We respectfully have to disagree with you Duke on this. May be a fluke on this car, but it works for us.Dick Whittington- Top
Re: TI
The single point distributors were assembled indifferently by GM and were poor performers from the get go. My 340 HP SWC rarely made it to the redline without breaking up in its first few years, but it probably saved me a broken connecting rod.
Once I figured out how to "blueprint it", it provided a reliable spark to the redline and beyond, so the single point can provide adequate spark for any OE SHP/FI engine that has a proper A/F ratio at the various operating conditions.
My experience with the TI is that is works perfectly or doesn't work at all, and failures occur without warning.
Duke- Top
Re: TI
It depends on how the engine is setup and what you started with.
Duke- Top
Re: TI
I can see the failure of the amp at shut down/re-start, due to the germanium transistors used and available at the time were prone to failure due to heat and vibration. We have had great success replacing those old transistors with silicon equivalent value transistors. Performance is as good or better and durability is excellent, as silicon units are impervious to the heat and vibrations experienced in an auto.
Mike Zamora
#12455- Top
Re: TI
Thanks, Mike Zamora
#12455- Top
Re: TI
We have found a more critical component that causes hard starting, is the strength of the magnet. Consistently, tests on our Sun Tester-OEM magnets will not excite the strobe. A change to the K&B coil P/U or just the magnet (w/OEM bobbin) and the strobe fires at very low RPM. It is our theory, since by definition the coil P/U is an electro-magnetic generator the pulse to the amp must be strong enough to excite the transistors. The Sun requires, by our readings, a minimum of 5.0v. AC to the pulse amp. The typical OEM unit reads about 4.4vAC at 500RPM distributor baseline test speed vs. a little over 8.0v.AC from the reproduction.
Based on these tests and some from one of our race customers, we have been changing out the coil P/U in favor of the reproduction with it's stronger magnet, when performance is the goal. We recommend the OEM bobbin for judging purposes.
If the change to an aftermarket module helped your situation-great, but I bet there was a problem with your OEM board that could have been fixed to perform as good or better than the best aftermarket unit.
Mike Zamora
#12455- Top
Re: TI
Clem-I understand the NASCAR boys used a redundant system of using 2 OEM amps back in the day, that they could switch from one to the other if necessary-was that your experience?
Mike Zamora
#12455- Top
Re: TI
Ken-as a point of interest, we have tested both the OEM amps that we have changed out the germanium transistors with equivalent value silicon transistors and see no difference in pulse output vs. the aftermarket modules. As a matter of fact on the M&H: it does not use the 12v. feed from the starter for starting, so is trying to start with about 7v.DC-the up-graded OEM actually unit has better starting abilities, because of the 12v at start. The Module from K&B tests well against the OEM on our Sun Tester, and uses the 12v lead from the starter.
Mike Zamora
#12455Attached Files- Top
Re: TI
Hey Dick-you seem to have great success with the MSD. It was my earlier recommendation to use like amp and coil-that is the recommendation of my race customers. Are you using the OEM type coil or the MSD coil recommended for their amp model you are using?
Thanks, Mike Zamora
#12455
The GM amps the NASCAR teams used were subjected to exteme vibrations, adding to the unreliability of these units. Like Clem, I used to rebuild these units for Corvette owners. I would get boxes of TI amps that were non-functioning (at one time there were 4 teams based here). That worked well for a while, until they started bedding the boards with GE Silicone Bedding Compound. Every try to dig electronic components outta that stuff??Dick Whittington- Top
Re: TI
Mike Zamora
#12455- Top
Re: TI
I hid the MSD Box behind the glove box door area on my 64 fuel injection race car. Worked great, in fact I found 2 seconds a lap with that one change alone over ignition points. Now that was 1988-94 time frame, but same should hold today.Over 80 Corvettes of fun ! Love Rochester Fuel Injection 57-65 cars. Love CORVETTE RACE CARS
Co-Founder REGISTRY OF CORVETTE RACE CARS.COM- Top
