68 back on the road-fuel & wiring question - NCRS Discussion Boards
  • Dale P.
    • September 30, 1995
    • 248
    after many years of letting my 427/400 HP t-top sit in the garage. i have started to get it ready for the road. I am getting rid of the tri-power (tired of all the fuel leaks from center carb) and going to a 69 390 HP intake and qjet set up .. of course i need to change the fuel lines, air cleaner, PCV valve, hose, and the list goes on .. but ran into an interesting issue . that is the throttle cable, cable support brackets at the firswall edge of the intake and of course throttle return spring ... what did I miss here? does anyone know if they are differnt tri-power to qjet? what parts do I need and where can I get them. pictures would be great.
    the other thing I notcied (didn;t before) is my car seems to be missing a fusible link at the starter for feeding the 12 volt acc circuit .. OOPs what should be there?
    thanks in advance for any input ..
    Re: 68 back on the road-fuel & wiring question
    Dale -
    Your '68 should have a 14-ga. brown fusible link wire at the big battery cable stud connection at the starter, with a molded cylindrical splice where it becomes a 12-ga. red wire that ends up at the screw terminal buss on the horn relay.
    • Clem Z.
      • January 1, 2006
      • 9427
      if the fuel leak is internal just block the the heat riser cross over in the intake manifold to prevent the gas from boiling in the carb.
