Ya I am still new at this,I am looking for the front end alignment specs for my 72 coupe with 350 engine and power steering. Thanks.
72 front end alignment specs
Re: 72 front end alignment specs
Gary, from 72 shop manuel, caster is + 2 1/4, camber is +3/4, toe in total is 1/4
rear aligne, camber is +7/8, rear toe is+ 1/16New England chapter member, 63 Convert. 327/340- Chapter/Regional/national Top Flight, 72 coupe- chapter and regional Top Flight.- Top
The Shop Manual and Assembly Manual specs are for bias-ply tires; if you have radials, front toe-in should be zero-to-1/16" total toe-in, and rear toe-in should be 1/32" per side.- Top
