64 Battery Post Area - NCRS Discussion Boards
  • Michael D.
    Infrequent User
    • April 30, 1987
    • 10
    I am in the process of reinstalling my battery. I am using a reproduction, dated Delco tar top battery, and a factory reproduction battery mounting setup purchased from long Island Corvette. The positive spring ring cable is very close to the hold down assembly, perhaps 1/4" from making contact. While it should not hit, I am uncomfortable with this close fit. There is supposed to be a felt washer that goes under the cable on the positive post. Is this intended to add a degree of insulation? Any comments as to this close tolerence is appreciated as I am sure others have encountered this discomfort. The concern of course is the dreaded short to the grounded hold down ass'y.
    Mike Delehanty
  • Bill I.
    • January 29, 2008
    • 554
    Re: 64 Battery Post Area
    Mike, I can understand your concern with the closeness. You should be OK with that spacing.
    The felt washer is designed to have a little motor oil on it to act as an aid to prevent battery corrosion. Bill
