My '61 1x4 carb was leaking gas at the inlet where the bronze filter is located. The fitting is a 1" hex. I cannot find the gasket (looks like paper) anywhere in Corvette Central or Paragon. I suppose I could try to make one. Anyone know of a vendor who has it?
Leaking carb inlet - need gasket
Re: Leaking carb inlet - need gasket
holley gaskets are soft aluminum colored black. go to a local speed shop to get the correct gasket.My '61 1x4 carb was leaking gas at the inlet where the bronze filter is located. The fitting is a 1" hex. I cannot find the gasket (looks like paper) anywhere in Corvette Central or Paragon. I suppose I could try to make one. Anyone know of a vendor who has it?- Top
- Top
Art------My '61 1x4 carb was leaking gas at the inlet where the bronze filter is located. The fitting is a 1" hex. I cannot find the gasket (looks like paper) anywhere in Corvette Central or Paragon. I suppose I could try to make one. Anyone know of a vendor who has it?
The original gasket was GM #3764576, aka Carter #121-319.In Appreciation of John Hinckley- Top
Joe: Thanks for the numbers. I also thought of using some thread sealer on the fitting. It worked for an antifreeze leak I had on the intake manifold of my '57. The fuel leak on the '61 could have been a disaster. Fortunately I discovered it while in my driveway.- Top
Art, my two cent on the thread sealant, if a piece does make its way into the needle and seat - you will have a problem, like flooding, not good, the factory or replacement gasket is all you need. EdNew England chapter member, 63 Convert. 327/340- Chapter/Regional/national Top Flight, 72 coupe- chapter and regional Top Flight.- Top
