Is there a correct bolt pattern when bolting the front end cross member to the frame?
There are eight bolts to each side, four bolts to the outside of the frame and four bolts to the inside of the frame.
Do all bolts go down thru or up thru or are some down and some up? My pictures show some of both but pictures dont show all the bolts.
If its going to be done, it might as well be the way it should be.
Thanks.
Thanks.
