I have my 65 in the shop to get the ac fixed. Just to pull off the compressor and take out the evaporator to send it out it get repaired, 10 hours labor, at 100 dollars an hour that's 1000 dollars just to take those two pieces off. Does that sound right.
how long should it take
- Top
Re: how long should it take
Ralph, being in the auto repair Business the labor sounds fair. and labor rates are different all over the U.S.
If your car is a big block or even a small block C2 its still a tough job on the evap. core removel.New England chapter member, 63 Convert. 327/340- Chapter/Regional/national Top Flight, 72 coupe- chapter and regional Top Flight.- Top
Why do you need to remove the evaporator?? Does it leak, or you just want to clean or replace due to age?? If it doesn't leak, leave it.
Older AC cars are a money pit.
Larry- Top
Evaporator core removal is a real pain. The compressor is a piece of cake. I think the man-hrs are realistic....even for a pro. The labor rate ($$$) is a bit high, but that depends on the shop and where you live.
Larry
Although the question of evap. core needing replacement is a good one. As this is one part that you should be sure that its got a leak,they seem to always have signs of a leak when just looking a the core itsself. Oil generally will leak out with the R-12 and dust collects onto that area of the leak. sometimes you'll find that a look inside the box through maybe the ballest resistor hole, if no signs there then its the electronic sniffer but there also not fool proof, they will false sense alot.New England chapter member, 63 Convert. 327/340- Chapter/Regional/national Top Flight, 72 coupe- chapter and regional Top Flight.- Top
Larry- Top
Old Motors (1970) for a '66 says 5 hrs just for the evap. plus the other items that have to be r&r to get at it. 10 hours doesn't sound out of line for all that is involved.Bill Clupper #618- Top
Ralph, are you a member of the Florida Chapter? If you haven't done so already, I suggest you ask some of their members for a recommendation for a shop in your area. Sounds like some of the shops you have used are parking garages, not service garages.
Best regards,- Top
I would not put much faith in repairing a 45 y/o evap core. Between the oil and typical corrosion of aluminum, it will be a tough repair. I believe that I would have a source in mind for a new core.Dick Whittington- Top
