Tire valve caps - NCRS Discussion Boards
Tire valve caps
  • Randy R.
    • March 1, 1983
    • 477
    Tire valve caps
    After reading the May 2nd post by Wayne Midkiff regarding tire valve caps, I looked at my spare and found a Schrader cap. So off to the junk yards I went. After combing through two of the three local ones, I found two damaged and one good Schrader cap. The one good one I found was on a early sixties Pontiac.
    Any suggestions on where to find more?
    What years were they supplied as an OEM or aftermarket item?
    Which brand of vehicles used them?
    Thank you,
    Randy
  • Bill I.
    • January 29, 2008
    • 554
    Re: Tire valve caps
    Why not try old gas stations/garages the have been around a long time. Might get a few. Bill
    • D S.
      • March 1, 2005
      • 1551
      Re: Tire valve caps
      If you are speaking of Schrader valve stem extension caps I assume you are referring to the black plastic ones with the white centers. There is a black plastic set on eBay with the metal ball centers.
