I searched and read the archive posts on this topic but have a question on setting up the shims correctly between the transmission mounting plate and frame on a '57:
If the "canceled angle" between the transmission output shaft and the pinion angle is set up to be close to zero degrees (or some other recommended angle?) by shimming, is that a preferred setup? Also, does it matter what the driveshaft angle is?
I am measuring off the oil pan rails and off the bottom of the rear housing to pick up my inclinations of the trans output shaft and the pinion angle (assuming the bottom of the carrier case is parallel to the pinion shaft).
After shimming the trans carrier bracket down 3/8", my measurements are:
pinion angle = 1 degree, positive
trans output angle = 1 degree, positive
driveshaft angle 9 = degrees, positive
canceled angle = (1-1) = 0 degrees
*all angles measured relative to the horizon
**positive defined as higher toward front of car
Therefore, the angle between the driveshaft and the pinion shaft is (9-1)=8 degrees with the car in its natural stance.
Does this setup sound ok, subject to a road test? Or, should I be shimming to a different angle to offset rear leaf spring travel under acceleration?
Dave
Dave
