Just found a very nice tire tub from a 1970 and it has a rockwell products sticker on the side showing from the rear, is this a normal part ? I have a feeling it could be a replacement, or did this come stock with the manufacturers sticker? Thanks Ed
1970 tire tub
Re: 1970 tire tub
Great,thank you, the date coincides with the car, good to know it should be there- Top
Re: 1970 tire tub
Interesting thread. Thanks!
I took my ('72) tub apart last year to restore it and found the Rockwell decal under the steel frame. Placement was so straight it looked like it was planned that way. Does anyone know for sure that the decal was placed before the tub was riveted to the frame?
Don Lowe
NCRS #44382
Carolinas Chapter- Top
Re: 1970 tire tub
I'm sure that it was. The labels were applied at the Rockwell plant where the tub was manufactured. I believe the steel support was attached at St. Louis.In Appreciation of John Hinckley- Top
Re: 1970 tire tub
Hi Edward,
I believe that that lable is actually part of the molded part and not a 'decal'. For example, you can see it but you can't feel it, or it's edge, with your finger.
I also found those lables under the front fender panels and on the underbody. The ones I found under the front fenders were high up where there was no black-out or sound deadening. As I cleaned the road grime off, the lables appeared as new.
Alan71 Coupe, 350/270, 4 speed
Chapter Top Flight October 2011- Top
