Re: Does this 1967 rear spring / leaf-spring look salvageable? (pictures)
That's a good test. Another would be to weigh a spring known to have no corrosion to get a baseline. A severely corroded spring will weigh less due to loss of material, but I don't know what weight would indicate the spring should be replaced.
Most old springs look a lot worse than they really are due to the ugly surface rust. Getting all the leaves cleaned up and doing a thorough visual inspection is still a necessary test. Minor pitting is not big deal, but if there are areas with major material loss, it gets iffy.
Due to the fact that replacement springs do not have the same engineering characteristic as originals, owners should make every attempt to restore the original spring.
