Rerestoration of a 70 L-46 - NCRS Discussion Boards
  • Edward S.
    • February 23, 2009
    • 43
    Well, after much thought and planning today i have started to disassemble my 70 for the second time. Did a complete frame off 7 years ago but now want to do it correct for top flight, have 99 percent of the original parts, but when i did it before I replaced most of the nuts and bolts with common hardware, i have the frame resto manual, my question is does anyone have documentation on the fasteners used elsewhere, like frame braces, bumper braces, frame extension etc. , any help would be great thanks Ed
  • Rich P.
    • January 12, 2009
    • 1361
    Re: Rerestoration of a 70 L-46
    Ed,
    send me a list of what bolts your looking to ID. I should have several setts of each application with appropriate headmarkings.
    • Edward S.
      • February 23, 2009
      • 43
      Hi Rich, thanks for the quick reply, i need all the front bolts, front crossmember to frame and the 4 that bolt the bumperette braces, the frame extension bolts, the bumper brace bolts, the radiator support bolts, the headlight frame bolts, in the rear I need the gas tank strap bolts and all the bumper brace bolts on each side, the gas tank frame bolts and the rear crossmember bolts. Beleive it or not I saved all the body bolts, go figure !!! Thanks again Ed
      • Rich P.
        • January 12, 2009
        • 1361
        Ed answers in blue below.....
        1. front crossmember to frame 7/16-14 x 1-1/4" grade 5 (lots of headmarkings ...M, A, WB, RBW, TR, and a few others)
        2. and the 4 that bolt the bumperette braces, Same as above
        3. the frame extension bolts, 1/2-13 grade 5 headmarkins same as above
        4. the bumper brace bolts, if these are the brackets that come off the frame extension then they are the same, all other front brackets with the exception of the outer bolt to the bumper ends (which are 3/8-16 grade 8) are the same as #1
        5. the radiator support bolts, are these the 2 that attach the radiator support to the front crossmember or the side bolts that attach the support to the fender skirts??
        6. the headlight frame bolts, 5/16-18 x 3/4" recessed hex head captured washer flat tip (manty headmarkings (B&H, F, IM, SEMS, Anchor and lots more)
        7. gas tank strap bolts 3/8-16 fully threaded grade 5 only headmarking is RBW
        8. and all the bumper brace bolts on each side, the 4 that attach the outer brrackets are the same as #3, tthe rest of the brace/bracket bolts are the same as #1
        9. the gas tank frame bolts 3/8-16 X 7/8" grade 2 most common headmarking C but there are others
        10. and the rear crossmember bolts. if these are the bolts to attach the crossmember to the frame (rubber cushion) then they are 3/8-16 x 1-1/8 or some times 1-1/4" grade 8 (headmarkings M,WB, TR, O, and others)
        Hope this helps and PM me as I have lots of the above.
        Any questins on other bolts just ask and I'll see if I can help
        • Edward S.
          • February 23, 2009
          • 43
          Thank you Rich, very helpful, and I will need all the bolts mentioned and am interested in purchasing from you any you can spare . Ed
            • 3415
            Hi Edward,
            I believe that Richard Fortier advertises in the DRIVELINE that he has a large selection of original fasteners. Perhaps he may be able to help you with some pieces that Rich doesn't have. 810-750-1472
            Also remember that often various head marks were used for the same bolt in the same location as suppliers varied.
            • Edward S.
              • February 23, 2009
              • 43
              Hi Edward,
              Thanks Alan, I`m waiting to hear from Rich on what he may have, and have spoken to Richard on some other parts in the past, great guy with a wealth of info. Thanks again Ed
