Third break light is not working. Have checked the fuses, replaced the socket and bulb - any Ideas on what is going on?
Third Break lights on 1992 coupe
Re: Third Break lights on 1992 coupe
Have you verified that you have 12vdc going to the HMSL when the brakes are applied? If not, I'd start there and trace back to where the wire originates, assuming the regular brake lights work.
DonThe light at the end of the tunnel has been turned off.- Top
Check out the brake light switch, my 89 had the same problem. The 3rd light power source is a "second" switch inside the regular switch.
I spent 10 hours tracing leads looking for something wrong and in frustration opened up service manual
saw the diagnostic on that light failure. Bought the $9 switch and all is well. So much time spent on such a simple fix!
Pete Bergmann
2005 - 2013 C6 National Teamleader- Top
