'67 Exhaust help - NCRS Discussion Boards
'67 Exhaust help
  • R N.
    • May 31, 2002
    • 640
    '67 Exhaust help
    Hello Everyone,
    I'm installing the N11 exhaust system purchased from Cor. Central for my '67 L79 and have a question regarding the installation of what some call the "alignment ring" for the packing. (It's item 322118 in the attached photo)
    From past exhaust work I've done, I remember this sleeve fitting snug into the front pipes, but the sleeve I have is so tight I would have to give it a few good wacks with a hammer and a piece of wood to make it fit. Just how tight should this fit. Anyone else have this problem.
    Re: '67 Exhaust help
    You'll find a couple variations in the construction of the exhaust sealing gasket: (1) made from rather soft fiber material, (2) made from a solid cast material.
    In general, the soft fiber gaskets are pliable and rather easy to install while the solid cast parts require 'coaxing' into position. The pro/con issue is the fiber gaskets don't last (heat fatigue) as long as the harder cast gaskets do.
    • R N.
      • May 31, 2002
      • 640
      Thank you for the reply Jack - it's the sleeve that I'm having trouble with. Sorry if my question was mis-leading.
        Kurt -
        If the sleeve is made correctly, it should drop right in place with no "coaxing".
        • R N.
          • May 31, 2002
          • 640
          Thank you John. I will see about having a local exhaust shop "swaged" the ends of the sleeve to fit or ask Cor, Central to send some new ones out.
          • Wayne M.
            • March 1, 1980
            • 6414
            Kurt -
            I was under the impression that GM original under-car 2_1/2" exhaust front pipes already had the "extensions" installed, as part of the assembly.
            But on the side exhaust, '65 AIM N14 Sheet 3 has a note: secure extension #3757555 to exhaust pipe by spot weld (3 places) equally spaced, or embossed (2) places equally spaced.
            I have an NOS BB set of N14's and could never figure out why the spacers/extensions weren't part of the GM side exhaust pipes/mufflers as well.
              Wayne -
              That "note" was removed from the Assembly Manual in January, 1966; I suspect it was an error putting it in the AIM to begin with, transferred from the part drawing for the supplier's use. There was no such assembly operation (spot-welding or embossing the extension) at St. Louis.
