Is the AIM set up in the same way the car went down the assembly line?
I am assembling the interior of a 66 bb from scratch. (nothing in the car)
do I run the wiring harness before the sound insulation or after. Does brake/clutch assembly go in b4 isulation.
how should I go about wiring harness and dash/ guages assembly?
I put in the heater box and figured out you cant get at the vents then
, so I hope there is a method to the madness that i could follow.
I am trying to follow the AIM but as a rookie I get easily distracted.
