I have a 1963 Roadster with manual steering. It has hard steering and I thought it was "normal" until I bought a 1967 with manual steering and what a difference. The 1967 turns so much easier
My 1963 was badly hit in the front years ago. I've owned the car for three years.
About a year ago I took the cluster out and of course took out the steering shaft.
When I re assembled everything, the shaft did not go right into the coupling so the alignment (or lack of) doesn't allow an easy entry into the coupling.
My question is: Is there an adjustment that would allow me to align the shaft with the coupling by moving the steering column about 1/2 inch to the right? This will allow the lower end of the shaft to line up better.
I'm assuming this is my issue for the "hard steering"
jerry
jerry
