Can someone help me with what the correct fuel pressure range is on my 89. Haynes says 34-39 .... The manual for the fuel pressure gauge for my year and car says 51-55..... Thanks dwf
Correct fuel pressure range?
Re: Correct fuel pressure range?
Doug, pressures spec.s are key on engine off 40-47psi and engine running pressure should be 31-44 psi. there is a wide variation but as long as your pressure is within those spec.s everything should be okay.
New England chapter member, 63 Convert. 327/340- Chapter/Regional/national Top Flight, 72 coupe- chapter and regional Top Flight.- Top
