rear upper shock mount bolt assy - NCRS Discussion Boards
  • Steve L.
    • June 30, 2001
    • 763
    The AIM shows a lock washer under the head of the bolt and nothing under the nut.
    This doesn't make any sense. Can someone confirm this for me please.
    This is for a 73
    Steve L
    73 coupe since new
    Capital Corvette Club
    Ottawa, Canada
  • Dick W.
    • 10483
    Re: rear upper shock mount bolt assy
    That is correct
    Dick Whittington
    • Steve L.
      • June 30, 2001
      • 763
      But I don't understand it, the nut is not a self locking type?
      Steve L
      73 coupe since new
      Ottawa, Canada
      • Paul O.
        • August 31, 1990
        • 1716
        Steve it is a clearance issue between the mount on the frame and the under body tub at that location. Hence the lock washer under the bolt head. The bolt and nut are a specific length and size. This has been noted on many original cars. Paul 18046
        • Steve L.
          • June 30, 2001
          • 763
          Guess I'l throw a little loktit on the nut.
          Steve L
          73 coupe since new
          Ottawa, Canada
          • Timothy B.
            • April 30, 1983
            • 5177
            Steve, I would not use loc-tite because if you ever need to remove it..
            The lock washer will hold it..
            • Roger O.
              • September 7, 2009
              • 209
              I agree. I've removed many many original upper shock bolts and the lock washer held them well.
              • Steve L.
                • June 30, 2001
                • 763
                OK, no loktit
                Steve L
                73 coupe since new
                Ottawa, Canada
                  Originally posted by Steve Lischynsky (36372)
                  OK, no loktit
                  Steve-----
                  A lockwasher in a clamping system is equally effective whether installed under the bolt head or installed under the nut. However, a lockwasher is not really a very effective thread "locking" device, at all. It will suffice in this case, though. You can use Locktite in addition to the lockwasher. Just use the BLUE Locktite #242. You won't have any trouble removing the bolt later.
