Is the above statement valid? Are there indentations for caliper clearance on '65+ frame kick up area? If so? A pic would be great. Thanks
Indentations in rear kick up for caliper clearance added in 65?
Tags: None
- Top
Re: Indentations in rear kick up for caliper clearance added in 65?
Yes; following link is to a related DB thread and the first pic should be just what you need.
https://www.forums.ncrs.org/showthre...frame&uid=8093- Top
Thanks for your info. Your link showed me that my frame had already been relieved.
Turns out,when the disc brakes were added. My frame was modified with the proper reliefs for the calipers. The bang or rubbing was my Addco rear sway bar. I shaved about an 1/8th of an inch off the inside ear of the bar on each side. All clear.
- Top
