Replacing my power steering pump and reservoir. Concerning sliding the p/s pulley on the shaft of the new pump, the Corvette Shop Manual (pg-9-20) says, "Do not hammer pulley." Without some kind of downward force, the pulley will not go down the shaft. Any suggestions on how this has been done successfully in the past?
I have the alignment "spline" fitted correctly into the groove on the inside of the pulley, and I have greased the shaft as well.
Thank you in advance for your replies.
Frank O'Donnell
Troy, VA
Frank O'Donnell
Troy, VA
