1958 Corvette Speaker Question - NCRS Discussion Boards
  • David S.
    • August 9, 2009
    • 595
    Hi Guys,
    I've seen some 58 Corvettes with the speaker bezel that covers the perimeter of the speaker opening in the dash and the speaker screen. Then I have seen some cars without the speaker bezel and just the speaker screen in the dash pad. Which is correct?
    Dave
  • Steven B.
    • June 30, 1982
    • 3976
    Re: 1958 Corvette Speaker Question
    Originally posted by David Schutzbank (50698)
    Hi Guys,
    Dave
    Dave, a post from last Nov. indicates no bezel on '58. Search 1958 radio.
    Steve
    • David S.
      • August 9, 2009
      • 595
      Steven,
      Thanks for that tip. I found a few threads that said no 58 - 59 ever got a speaker bezel. My next question is if this is true, how does the speaker grille and speaker itself stay in place?
      Dave
      • Dan H.
        • July 31, 1977
        • 1365
        David, there are 4 'T' bolts resined into the perimeter of the dash fiberglass pointing downward, see AIM for details. The spreaker and grill are inserted from bottom and drawn up into the opening.
        1964 Red FI Coupe, DUNTOV '09
        • Loren L.
          • April 30, 1976
          • 4104
          I believe that you find the "running change" adding the bezel occurs sometime in 1959.
          Also, unless the pads have been changed, you will find that the speaker does not install level with the pad without changes in the means of attachment.
