Do the judges look for these ? I believe they are only on the inside. I'll be mounting Bias Blackwalls soon and want to make sure I don't need 42 year old weights. Jeff
Wheel Weights
Re: Wheel Weights
Yup. Don't forget who you're dealin' with. Compared to the tiniest other things scrutinized, weights are elephants in the room!
You can get some from Ebay and from someone (whose name escapes me right now) who advertises in the Driveline.- Top
Re: Wheel Weights
Hi Jeff,
I believe the weights had the word MICRO on them in raised letters. The ones in use in 70-72 (at least) had a cast 'crease' in each end that the judge can feel for even if he can't quite see the weight (thanks Steven!).
I believe the weights (and valve stem caps) can still be found at the 'right' auto salvage yards.71 Coupe, 350/270, 4 speed
Chapter Top Flight October 2011- Top
Re: Wheel Weights
Hi Jeff,
I believe the weights (and valve stem caps) can still be found at the 'right' auto salvage yards.Terry- Top
Re: Wheel Weights
Jeff
Yes the weights should only be on the inside of the rim.
Attached is a picture of the wheel weights from my 68 original spare tire. It has the weights of two different manufacturers side by side.
JohnAttached Files- Top
Re: Wheel Weights
Jeff to help you in your search others besides MICRO and a H in a circle were used. The others I have are a 14 in a circle, MCH, DEKA, HH, SNUQL, HALKO, <CH>, and weights with a arrow on them. I am sure that others exist. The important part is that the weights have fractional numbers on them not metric.- Top
Re: Wheel Weights
Another suggestion;
Especially if you will drive your Corvette.
It is difficult to get a true balance only placing weights on the inside.
Use tape weights on the outside and place them where not visible w/ the trim ring or wheel cover in place.
Just my 2 cents.
RayAnd when you get the choice to sit it out or dance
I hope you dance
- Top
