I have A saw blade wheel of took of 94 that the clear coat was peeling. I was going to have the rest chemically removed and try to restore it my self. what type of clear coat can I use
clear coating late C4 wheels
Re: clear coating late C4 wheels
Keith, I believe that the clear coating on wheels is powder coated which is more duriable, I don' t know how the spary can clear will work, but I would say it maynot adhere as good as the factorys.New England chapter member, 63 Convert. 327/340- Chapter/Regional/national Top Flight, 72 coupe- chapter and regional Top Flight.- Top
I was not thinking of using spay can clear.- Top
Edward------
I believe the coating used on original C4 wheels was some sort of a hi-tech paint and not a true powder coat. However, if I was going to have a wheel re-finished I'd go with a powder coat. In fact, I did just this for a secondary set of wheels for my 1992. I obtained an original set of used 1992 wheels which were structurally sound and stripped of original finish. I took them to Wheels America and they completely re-finished them with a powdercoat finish but in the exact configuration of the original painted finish. These wheels came out ABSOLUTELY PERFECT. They could not be discerned from a brand new, original wheel.In Appreciation of John Hinckley- Top
Keith-----
Yes, the information is in the service manual. However, it may very well be that some of the materials specified in the manual are no longer available.In Appreciation of John Hinckley- Top
