I have never removed a harmonic damper before. The enclosed pictures are of the tool I am using and the damper. I installed the tool with three bolts, then the center bolt looks like it pushes in on the crank while the three bolts are what pulls it off.
I got to a point where the center bolt was tight against the crank, and it would not turn anymore. I applied more pressure and the crank is now turning.
Am I doing this correctly, and if so, how do I stop the crank from turning? For the center bolt I am using a pointed tip, there is also a flat tip I could use. I used the pointed tip so it would help align the bolt, but I do not want to mess up the threads.
Todd
Todd
whack the end of the bolt with a large hammer, 4# or more. Usually that will start the pulley moving, you may have to do this two or three more times when the puller starts to get tight again.
