I am thinking about installing power brakes on my 67 convertable. From my reading there seems to be differing opinions regarding weather it's worth the effort to install this option.
What's the difficulty level involved in this installation. I would want the conversion to be as factory and I am not sure that is possible. How hard is it to install rivets for the nut plate and does the rear brake line need to be changed. The front would not be a problem but the rear??
Inside the car, what changes need to be made. I read that two studs need to be knocked out and the brake return spring is not used. What else am I missing..
Also need to locate a 5867 booster and can reuse my original master cylinder..
All comments are appreciated.
