Re: "326" Water Pump Shaft Failure
Joe,
It was good to meet you at national. Always better to have a face to connect with a name.
Just a thought, as I recall a needle bearing is designed for a Rc 58 hardness on the shaft surface ( I'm going back to my design years so may be off). As the metal is made harder it becomes more brittle. So could it be possible the stress risers if not drawn back cause issues as you experienced? I don't think the intent was to thru harden the shaft only a surface hardening was necessary for the needle bearing. Something about carbonizing to complete the hardening process sticks in my mind.
Joe,
