63 convertible deck clearance - NCRS Discussion Boards
  • Steve D.
    • February 1, 2002
    • 990
    The rear deck clearance aon the sides is very tight. I don't think it was that way before I installed the Keisler 5 speed. During the 5-speed install I added the later C2 aluminum spacers (as per Keisler instructions) to get a skosh more clearance for the transmission. Could that have changed the geometry of the opening where the deck fits?
    Steve
    Re: 63 convertible deck clearance
    Steve
    Steve -
    At what body mount positions did you install the spacers, and how thick are they?
    • Joe C.
      • August 31, 1999
      • 4598
      Steve
      If you need to lift the body to gain clearance, the smart thing to do, is to lift all 12 attaching points by the same amount.
      • Wayne W.
        • April 30, 1982
        • 3605
        I agree, but it really shouldn't close the gaps on the sides of the deck lid, no matter what shims were used. Some of them are very tight.
        • Steve D.
          • February 1, 2002
          • 990
          John
          It's my understanding that the 63 didn't use any spacers, but later C2s did. They are about 1/2" thick. I misspoke about the aluminum. Only the two front mount spacers are aluminum; the others are rubber.
          • Wayne P.
            • January 23, 2008
            • 444
            You might have to add shims to rear mounts. Would you have a pic?
