My 72 (base engine) automatic intermittenly will start up and run for 15 seconds then die. Their is no fuel shooting from the jets when the throtel is pumped. If the choke plate is held closed it will eventual start. I replaced the fuel pump, filter, and hoses from fuel line to pump and line to the carb. Fuel poured out of the line when disconnected from pump, blew air into return line and heard it in tank. Lines are not leaking, orginal carb was rebuilt and float is not stuck in the up postion.
If you pour gas in the carb it will eventually start up. any suggestions onwhat else i might look for?
