I'm not certain if I can do this on the TD board but I need a solution to a restoration problem, so here goes. Upon disassembly of my differential I found that one of the 4 bolts that attaches the rear spring to the diff cover was installed with a very thin washer. The result was the bolt piercing the cover. I'm reluctant have the break welded since this is a high stress area. Does anyone know of someone that may have a good used '64 differential cover for sale? Any leads will be much appreciated.
Thanks-Doug
Thanks-Doug
