'66 Brake lights not working - NCRS Discussion Boards
  • Daniel J.
    • July 29, 2007
    • 158
    Brake lights worked just a month ago and now they do not.
    I checked the switch while in the car and had power to the orange (wire) terminal, but none at the white (wire) terminal.
    I took the switch out and bench tested it and it had power coming out, so
    I re-installed to find out the same problem...no power coming out.
    I am baffled...any ideas? (FYI...I have replaced my signal flasher unit recently)
    Dan
  • Wayne W.
    • April 30, 1982
    • 3605
    Re: '66 Brake lights not working
    Short the wires together and see if the lights work. If they do, you know its the switch.
