Harmonic balancer for '70 454 - NCRS Discussion Boards
  • Steve G.
    • December 12, 2008
    • 192
    Am finishing up engine rebuild. Harmonic balancer rubber is cracked / brittle. I am looking for least expensive solution that will function properly and look correct. Does anyone recommend rebuild vs buy new? If new, is GM replacement (not sure if they even have a replacement) any better or worse than calling local parts store? thanks, Steve
    Re: Harmonic balancer for '70 454
    Steve------
    There are quite a few options for a new balancer:
    GM #10216339------about $250, GM list
    NAPA #BK6005209----about $75
    Dorman #594010------about $50
    The NAPA and Dorman pieces might be Chinese-manufactured, but that does not necessarily make them bad.
    I think that any of the above will, once installed on the engine, be pretty much undetectable from original.
    I don't know what a rebuild would cost for yours. Contact The Damper Dudes or Damper Doc, both located in northern California (Redding or thereabouts, I think).
    • Steve G.
      • December 12, 2008
      • 192
      Thank you Joe! Given that info, I will buy an aftermarket - probably via Napa as there is one local to me. I'll store away my original in a box... Steve
