67 Original Washer Cap ID Help - NCRS Discussion Boards
  • Dereck S.
    • July 30, 2008
    • 244
    Looking for help identifying if I have a correct original washer cap for my 67 BB. I've attached a picture of what I've been told is an original NOS washer cap with a diamond embossed on the inside and a lip on the tab that does not go all around. It also has a number 7 embossed inside. A picture of my cap is also attached. It also has a lip on the tab that does not go all around. However, it has embossed inside the letters FPS with the number 1. Is my cap correct? My ejector pin marks on the tab are also located differently. What does a correct cap look like?
    Dereck
  • Jack C.
    • September 30, 1992
    • 1090
    Re: 67 Original Washer Cap ID Help
    My bet is that the cap which you say is your original one is the one that came with the car. My early 68 cap is the same as yours. NOS can be a service replacement part.
    Jack Corso
    1972 Elkhart Green LT-1 Coupe 43,200 miles
    Top Flight 1994, 2018 & 2021
