May 31, 1962 Built vette.
The AIM shows that the retainers used to hold the rocker panels are one long strip mounted under the doors, however, on my car I have 4 smaller black section retainers- See the pic.
Is this correct, or did a previous owner change something?
Also, on the screw/nut assembly that mounts the lower edge to the car, should the small lock washers be copper?
Tony
Tony
