The 4-speed shifter console that came off the '67 (called the "3897484 Trim Plate ASM Chart" in the Assembly Manual, UPC 1ASM, Sheet E3) has warped in the 'fork' area. The 'forks' are spread apart too far, one side more than the other. The paint was already missing.
The underside looks great, the top side is dirty but the chrome cleans up pretty well. There is just the beginning of tiny "bubbling" under the chrome in a couple places.
The second example (with black paint, not original to this car) does not have the same warping of the 'fork' area, and has more evidence of bubbling under the chrome, but not a lot. Both shifter consoles have casting number 3860149 on the underside. I would like to use the original and have it restored, if it makes sense to do so.
Is this kind of warping common? Can (or should) it be straightened during the restoration process?
Can the minor bubbling under the chrome in two or three spots be fixed prior to re-plating? Restoring the shifter console is a relatively expensive process, so I would like to find out whether the original "core" I'm hoping to use is acceptable.
