Hey all....
I finally have gotten around to fixing the oil leaks from the intake manifold side rails.
I discovered after removing the intake that there was a substancial amount of oil comming up throughthe bolt threads that are open/thru-threaded. It also seems that some oil was being sucked into the intake ports in the heads, from the bottom side of the intake ports.
What can I do to prevent the issue with the bolts?
I have a NOS gasket set I was planning to use.
Would it be better from a sealing standpoint if I used a different gasket manufacturer for side gaskets?
I will use the GM rail gaskets since they have the tabs on them.
I need to strike a balance - reliability/sealing and judging.
Also ----
I noticed a build up of a hardened black substance on the valves, while looking into the intake ports. A couple of the valves were open enough I could somewhat see into the chamber, it looked to have carbon build up.
I use a can of SeaFoam with each fillup - I was told by a long time mechanic that it would help prevent the build up I noticed.
Is there a better additive I can use in the fuel to help cleanup things?
Any insight and suggestions are GREATLY appreciated!!
Also ----
